xjcritter
- May 3, 2010
- gastonia/clover
allright i got a 98xj 4x4 with the 8.25 rear axle geared 3.55. all stock. when I make a sharp left turn from stop it grinds/vibrates some times almost sounds like the gears are grinding together. When I accelorate I makes a fairly heavy vibration and at speeds its a steady vibration. Ive been told its in the xfer case[wich is a 242j] pulled the fill plugg to look at the gears in there they look fine. The chain feels tight from what I can tell I havent removed it. Pulled the diff cover off and inspected the gears they look fine as far as I can tell everything looks ok. Ive replaced the u joints in the rear axle and the fronts are basicly new. Im trying to fix it before it gets worse cause its my DD so if anyone has a hint or can swing buy and help me with this I could throw out some gas money an maybe a little more. I am toatly clueless about axles so any help would be great. Thanks guy
