awilson
- Feb 14, 2011
- winston-salem
keep getting a 303 misfire code on my 01 Cherokee Sport 4.0, changed plugs wires, still get code back every 2 weeks, any ideas what else to look for? Thanks
is this recall only for the 2000-01 XJ?if its a cylinder 3 misfire or a cylinder 4 misfire there was a recall from that due to the injectors getting too hot. the way they fixed it is the installed a heat shroud around the injectors. you can get it from the dealership
