So it’s a load test thing and not just as simple as testing voltage.
Thank you.
Eggs Zachary.
Here's my favorite analogy intended for the non-electrician.
Imagine that a battery is a crateful of tiny little oompa loompas that are anxious to get out and do some kind of work. One useful metric is how anxious they are to get out - voltage. Another is how quickly they are going to run out and do some work for you once the door is open - current (amp).
Measuring voltage is easy. You basically just ask the oompa loompas how excited they are to get out. They give you a measurement of potential. If it's really high they're going to do everything that they can to bust out as quickly as possible, even if that means blowing s*** up in the process. If it's low they are only slightly motivated and only a small amount of work is going to go into getting out. If you ask too much it just won't happen.
Asking how quickly they are going to get out isn't really a fair question because it really depends on the size of the door that you open up and the size of the hallway they have to run down in order to get to their work site, and how much work is waiting for them on the other side. If you open a really small door they are going to go as fast as they can but it's still not going to be very fast because the hallway is just too small, and if they get there and there's no work to do they're going to be pissed. Only enough we'll go to get the job done and no more. If you open a giant door and have a huge work load on the other side then a whole bunch are going to run out all at once and get you a ton of work done.
But the point is in order to get that measurement, you have to actually measure how quickly they will run through the hallway based on the size of the hallway and how much work you're giving them to do in the first place. It's not as easy as just asking them how fast they'd like to get there.
Resistance by the way is just the size of the hallway ;-).
And it sounds to me like you need a replacement set of oompa loompas that are a little bit more motivated
