timberlan99
Member
- Aug 16, 2007
- richmond county NC
I have a 1989 cherokee with a rustys 4.5 lift it has the t-case 1in drop. The problem is when i put it in 4 low and start to move it will pup out of low back to neutral. it will stay in low as long as it is in foward moton but if i gas it and let off the slack lets it pop out. my question is, When you lift the cherokee and usethe t-case drop spacers do you have to modify the shifter linkage. it seems to not go all the way in low.and when i put it in low and go under and unhook the linkage i can move the tcase shifter back further. I would appriciate any light you could shed on this for me...
thanks
thanks
