Pinkston
- Mar 21, 2005
- Mebane, NC
I have an odd ball set up, but I figured this would be the best place to ask. In my isuzu trooper I have a 4.5 V8 out of a 1990 cadillac deville. The motor has a chevy 350 throttle body on it with a chevy caprice 350 computer running everything. The trooper came with a GM 2.8, so the wiring harness did not need much modification to make this motor work.
The motor has been in and running for over 6 months with zero problems until last night. I was pulling out of the drive way and it cuts off all of a sudden. Now it wont start back up. After looking at some things I found that it is getting spark, it is getting fuel into the throttle body, but fuel is not getting past the injectors. I am 95% sure the injectors are not the problem. I had a spare injecor that I put in and it still has the same problem. I also tried a spare computer and had no luck. I know the fuel pump is working and getting fuel to the throttle body.
Its an oddball set up, but does anyone have any suggestions?
