chevy 63" springs
Chuckman
Huntersville
so my YJ SOA setup on my heavy CJ is dead, they are bent into oblivion. I saw a yota running the 63" setup and he had zero spring wrap. they looked like they flexed good too. will they continue to NOT wrap, or were these still new perhaps and not loose-y yet. I dont like to run a anti-wrap arm, I keep breaking the shackle bolts or twisting the mounts. so anything that I can do to not run them would be great. anybody seen them mounted on a CJ? what kind of lift are they?
I used to run a set 52" 1/2 ton chevy springs soa with fulwidths on my yj. I kept the factory overload on the chevy springs and never had a problem with axle wrap. If you need anything hollar at me.
they are made for 1/2 ton pickups so they dont flex the greatest, but still do considerably well. they probably wont ever sag much under a yj, also i know on a stock toyota setup they will net you about 2in of lift
