chevy questions
zmancj
Sylva
I have a 81 cj5 with a 70's model 350 motor and th350 tranny. Here recently it acts like it wants to cut in and out when i get up to 65mph and now it is doing it at 55mph. I think it is something to do with the fuel or maybe the Catilitic converter is going bad. I have replaced the tranny gasket and fluid, it goes through all 3 gears smooth as can be. I have also replaced the fuel filter, and PCV valve. the carb was rebuilt in December and a new fuel pump was also put on at the same time. I figured i would see what yall think before i take it to the shop. Any help would be greatly appreciated. Thanks Zack
The cam is original and it does have a mechanical fuel pump. I have not checked the grounds ill try that thanks.
are you still running the small factory jeep fuel line you need at least 3/8 line and the pump push rod should move at least 1/2in in & out
