Chipped Ring Gear Teeth. remember this post from sept.
storeman
Known by Few
Whiteville nc
:confused::( I got the rear fixed back before Dixie Run I hope it is right. So last Saturday I take my
Jeep to the CTB Christmas party ride at Scott fields Big Creek property, the very first climb I loose 3 or 4 teeth on the front Dana 30 Ring Gear. The Back now the front it has got to be related.
The thing that bothers me is the shop that fixed the rear in September said that the set up
looked right and it must have been something else . The original guy who set them up is no longer in business. That goes against a lot of what was sad hear on the
board. If y'all are right what I have now in the back could be wrong. IDK what I am going to do
at this point. I have talked to a shop in charlotte but that is a long way 3.5 hours and don't know him either.
I feel like when I have the front done I need to have the rear checked out to make sure it is right.
Maybe Doug and I need to take a shot a the front ourselves. My Status now Broken and
Confused . I will post some pictures tonight they are on my laptop at home but there was
one whole tooth missing by it self than half way around the destructive 3 to 4 tooth loss.
The Spartan held true and I finished the day limping along.
At least we now know what the problem was! I would definitely get a competent, trusted R&P setup tech to check the rear when the front is fixed!
unless you have access to the right tools or the money to spend on them...DON"T DO IT YOURSELF!!!! I just went through this on my front 30. To be sure there is a shop from Whiteville to Wilmington that can do it. Hell,take it to ECGS up in Raliegh and get it done. If you decide to go with ECGS,we could work something out on getting it there and back.
the best I have now
Take it to East Coast Gear Supply. I shipped my 9" centersection to them to gear and install the Detroit, they shipped it back, and have never had any problems.
Another vote for ECGS. Too bad you can't just ship it to them like a 9" third member. I would also consider a R&P with a lifetime warranty like we talked about. Also like someone else mentioned and we talked about on the phone, gears have to be set up perfect to last. Especially when you are being spotted by Doug who's constant instructions are "back up, back up, ok there's your line. Now nail it!"
I dont know who setup the gears so im in no way defending them but is their any possibility that you found the breaking point of a dana 30 gear set?
I cant tell the pattern due to reflection but it looks like their was a full pattern and the whole tooth is broke off suggesting that full contact was made befor the destruction.
Had the pattern been off the tooth would not be completly gone in the center.
If ecgs is within a reasonable distance I would take it to them.
Buckeye Performance Inc.
828-779-2242
Quote
Quote
nail it!"
Quote
You all have good points. I guess my thinking was do you need more than a 30 on 33's? I really have not planed on bigger
tires.
Doug does push to the limit that is his style. I tell him he is break proof with a 3200 pound Sammy on Toyotas that
would be like a 4300 pound jeep on 60's IMO
we say we rock crawl but a lot of times that ant so just look at my video post.
I am going to have the 30 fixed and check the rear. If it is determined the 30 was right I will have to give my wheelin
style some thought. At heart I like to consider my self a rockcrawler which is how I prefer to wheel. not a beater. But when you go places like Dixie run
with a friend like Doug and a good friend don't get me wrong. When we line up for the trails he wants to follow the buggies and I want to follow him even though sometimes I know it is not a good idea and I end up pushing it I know. But we have had some fun. It may be costing me now IDK
Could also look at Carolina Truggies or Tarheel4WD for new gears. Would be a little closer than ECGS.
33's on a dana 30 is just fine the trick is knowing when to back off while doing the "bump" watch your vid very close and you will see when your front bounced. That bounce is probably what broke the gears.
828-779-2242
just out of curiosity, what was the manufacturer of the gearset? looking at it, from what i can tell in the pictures, the contact on both the drive and coast flanks looks good, the setup appears to have been right. it would be interesting to check the hardness and the heat treat case depth on the gearset. that being said, did you ever bounce on the gas really hard or go from spinning hard to suddenly getting bite? a hard shock load could cause damage like this as well
My first thought was just cheap or weak gears and a little bit of shock load. If I were you, I'd save my lunch money for something like a 44 front and an 8.8 or 9" rear and be done with it. Too strong isn't a bad thing!
I watched the video over and over last night . I think I see what you are talking about. It is that last bump just before I run off to the right. It does not look like the tire stopped but maybe it was shock load I guess all it takes is just a second to do the damage. It seems weird that in 7 years of this I have never broke a front axle. I have found thrown joint caps on a couple of post ride inspections. We Replaced the joints and spot welded the caps . Just before the Harlan trip last spring
I noticed some of the welds were broke and the cap had spun a bit. So I ordered some 27 spline Alloy USA shafts and joints.
The last thing I wanted was to haul my mess 500 miles and break. Do you think the new shafts made the ring gear
the new weak point.
Also can gears fatigue over time and become weak or do they just fail all of a sudden ?? Because I am certain I have done this type of bump before.
Thanks for all the responses
Since you are doing gears anyway, get a XJ HP30 and swap over everything from your lp30. You'll have a much stronger gear set that way.
From Joe Jones Have you considered taking Scotts 101 class?
I may should sense I posted his banner add in my Video . I like Scott he is a great guy . I am positive I can always learn something more. I don't consider myself a natural when it comes to picking a good line on something like above. My favorite
type of trail is rocky frame twisting dry river beds like Crawford's cry Harlan or the fun part of dickie bell and the long hill climb on Daniel. My weak point is Ledges when I broke a rear 44 a few years ago it was bouncing on a ledge ,skinny pedal
happy. It happened so fast it was crazy.
learn the limitations of your rig or pay the price over and over. Bigger rigs than you will run you up on a snag everytime if YOU don't keep YOURSELF in check.Another thing.Stop letting Doug spot for you!!! I had a spotter one time that caused me to spatter spider gears in my dana25 and twist my rear driveshaft in 2 all at once a few years back trying to get up on the first ledge on daniel. Asked about a noise I heard and all I got out of him was "dunno but if you hit it one more time...". Sound familiar?
You have a good point It is hard some times to keep
Yourself on check You get caught up in the
Moment and that 1 min of fame is gone and forgotten
I am going to look at my old ring gear from the rear
And see if there is any info on there I will post that
Up tonight
I ran 31's the first 4 years I started doing this and wheeled hard
With no issues. Only when I went to 33's did I have trouble
They are quite a bit heaver and wider on the 10 inch
Wheels plus they seem to b a little Taller than the average
33 . they r Made by interco.
I think the rear44 is ok size wise but may consider
Something else for the front If I do I will not fix the 30
And just sell the alloy shafts and locker.
Like someone said earlier, you might as well get a hi pinion d30 from a Cherokee and swap in your locker and chromos since you have to have new gears anyway. I think the HP d30 is stronger while moving forward but not as strong in reverse as a standard d30. I dunno don't quote me on that. But its something to look into.
sent from my jeep on some trail in the middle of nowhere
That is correct.
Maybe you bandaid this thing up with a new R&P and consider a full width D44 in the near future? You figure the money you have in a 30 and still have a weak carrier and gears, the money you could sink into it and still do this again at some point may be worth the upgrade. It took a lot of waiting for the right deals but my 44/9 swap costed about $600 total after selling my previous set up. And with Doug's fab skills you could easily do it with some junk yard sourced axles and have a very solid set up for a good price.
Fluke. Maybe bad gear set, maybe bad setup, maybe too many shock loads, maybe just a Dana 30.
I'm with the other guys... If you have to buy a new R&P anyway, you'll get some strength advantage from a HP axle. You could even have the gear setup done in the bare housing and then swap it over at your leisure. Or stick with what you've got.
I agree with the above. Either change your wheeling driving style or upgrade to bigger diffs in general. I broke some stock 44 stuff with just 35 tsls it was all bad timing and the right foot. 33's and a 30 will net the same result. Your axle upgrade most likely netted the ring gear the new weak link. Your probably lucky you didn't explode the carrier. Stock spiders probably would have let loose otherwise. Build better and save on rebuilds for the life of the Jeep, just be patient and build once to suit your needs and style. Shock loading any hardened part near its yield strength will deteriorate its ability to handle loads. Think about it like hammering on mild steel. It doesn't do much at first but after repeated blows you get results. Hardened material is the same just takes longer and the break is more unpredictable, because with hardening you loose ductility. This is why a cryogenic treated gear just fails huge when it goes. Its so hard its has almost no ductility (meaning ability to flex a little). Flexible gears would just wear into mush. Burnt, galled, deformed gear faces, or toasted gears are usually bad set ups accompanied with noise and vibrations. Sheared teeth are mechanical damage in nature. Meaning too much force, torque, skinny pedal, horse power, wheel hop, tire size...................you get the idea. Poor set ups have tells that show up before boom! Chipped teeth are damage front the same type of loading just not as harsh to penetrate past the hardened gear tips and face. An improper set up with way to little gear mesh will net crazy backlash numbers that are hard to shim out. Most of the time to little contact will howl and vibrate due to the teeth not sliding past each other correctly. The pinion shape in nature must slide past the ring gear. Its do to its very steep helical cut. This is why backlash is needed in some amount to allow for lubrication of the gear face. Tighter back lash will gain some strength (most debate this cuts down on shock loading) but to tight you loose oiling capability and build heat. Sometimes to the point of gradually annealing the gear face and making it weak over time. Way tight, instant heat and degradation (low millage burnt gears).
I have a couple of busted teeth in my front dana25 from the spiders granading.A piece of a tooth was hidden way in the back and it didn't come out when I repaired it.Next wheelin trip and it came out and wedged between the housing and teeth and broke them off.I wanna fix it but thats been 4 years ago and it's still hanging in there.Did you have some earlier damage that might have left a chunk of metal in there?
