CJ / YJ door swap
Chuckman
Huntersville
Will a YJ door (top half) fit into a bestop (CJ) 2 piece door bottom? I need to get away from the rounded upper corner and the YJ's are what I need. Or is there a CJ door that had pointed corners that comes in 2 pieces?
My old CJ Bestop doors had the pointed corners
I think the 'newer' Bestop doors for CJs (maybe YJs) were a little different. See how the split between my upper/lower is one diagonal line. The ones I see now are different, the split line is horizontal on the rear of the door, then angles up at the front half. I assume those doorframes would be different than mine.
There are so many soft doors out there, I wouldn't bet on anything unless you are able to match it up in person.
