matt1u2
- Apr 23, 2009
- florence,sc
I have a 77 cj5 stock drive train with a 304 and 3 speed drumb breaks at all four corners. I would like to upgrade to discs. I want to build to be able to do moderate trailing/crawling but still be able to drive it around town. I have installed a 1" body lift. It currently has 32x10.50. I plan on doing a lift with either suspension or SOA to run 33-35". But not till over the winter. My qustion.
I have a chance to purchase a wide track 30 with disc breaks for the front axle with 4.10 ratio. Also have an oppurtunity to purchase an 8.8 with disc and 4.10 for the rear.
I realize the bolt pattern is different on the 8.8 so I would have to get spacers to change pattern. Also the 8.8 is wider than the 30 so I would have to specer the front axle also.
I can get both axles for 225.00.
Am I correct in my thinking? Also, is this going to work and is it worth doing?
