Bullardbs
- May 7, 2007
- Thomasville, NC
I took my bronco down to ure today with Doc and found out that the front leafspring setup on the bronco needs to go away. The leafs wraped bad and bent and it sent the front drive shaft into the trans shift linkage so had to crawl under the truck to shift and after every bump had to crawl back under and shift it back in drive. Made it almost to the parking lot and one of the trans lines let go and the trans went out as we made it in the lot. Had to winch it on the trailer with some rachet straps because the battery died also so the winch was no good at that point. So to say the least I learned a lot today and found out that I need to link the front so should I go with coils or shock and if shocks how much travel do you guy run in the front. My rig is a 90 bronco 2 with a efi 302 and has a hp 44 front and 8.8 rear going to a 9" in the rear soon.
any ideas will help
any ideas will help
