madssjeep
- Nov 27, 2005
- Huntersville NC
ok this is what I have. stretched CJ-7 to 110" triangle linked rear on factory front xj springs. my problem is under compression the compacting spring tends to fold over.
Is this a normal problem related to coils? are bump stops the only answer? coilovers will solve the problem but I will take that step only if I have too or if I score on a lotto tick. looking for some creative ideas.
here is one Idea I had, since the suspension is located via trackbar side to side motion is held in check. I might be able to use the same style hiem joint mount as a coil over on the bottom. The bottom spring mount will be able to compensate for the angle via the pivot point. what do you guys think. Is this thing going to work or will it leave me with a completely useless spring lanching, frame landing on axle contraption.
