thewagonmasternc Well-Known Member Joined Jul 10, 2006 Location Granite Falls,NC May 14, 2008 #1 What size DOM tubing ,and wall thickness ,would I need for this,using 1Ton TRE's,putting this on a YJ with a Dana44hd,thanx
BigWheelBob Well-Known Member Joined Mar 31, 2005 Location hubert,n.c. May 15, 2008 #2 1 1/4x.213 wall to direct tap it, or 1 1/2x.250 wall to use with inserts.
ncjeepers Well-Known Member Joined Apr 13, 2005 Location Locust, NC May 15, 2008 #3 I have some 1.50 OD x .25 wall and 1.25 OD x .125 wall if you need some. I also have threaded inserts. I normally use the 1.25" unless someone is at 40"+ tires or want to go hydro-steer.
