lomodyj
- Mar 21, 2005
- Out in the Middle
In my attempt to recover from my melt down. I've replaced all the injectors with 215's from PDR. Followed their instrucions for install. Put the truck all back together. Did a line bleed (leave fuel line to injector fastener loose and crank till they show fuel then tighten down). Got all injectors showing fuel, tightend them all down. Restarted, ran fine, went to bleed again while running (as per PDR instructions). Loosened 1, idle dropped back, re-tightened ran fine. Loosened 2, idle dropped back, re-tightened ran fine. 3 and 4 were the same. Got to 5, loosened it and it stalled. Cracked the fitting open again and gave it a crank. Plenty of fuel squirting (at least it's the same as 1-4), tightened everything down. Now It won't start at all, just crank...not even a hiccup to make me think it might start. All wires seem to be where they should be, I've installed 2 new batteries (cranking killed a cell on one of the old ones), Fuel shut down sel. moves up when cranked...
What else should I check??????
