Tacoma747
- Mar 20, 2005
- Winston-Salem
So I had this engine rebuilt, I am finally working on putting it together to install in the truck. Went to put on the harmonic balancer and the TDC mark doesn't jive with the injection pump TDC mark. With the timing cover removed, all the marks are correct, injection pump gear TDC mark is vertical and in line with the mark on the timing cover. Everything I have found online states the harmonic balancer TDC mark should be vertical at TDC. Obviously I can put it on 4 different ways, but none would be TDC (red lines are my choices). I pulled the timing cover to make sure everything was right just because it doesn't make sense that the TDC marked don't jive.
Any ideas?
Any ideas?
