madssjeep
- Nov 27, 2005
- Huntersville NC
last fall I decided to start the cj over. pull the tired 304, cut the body in half, cut the frame, wanted 37" heavy duty rear, 5 speed. You know, the works. well It is getting close to beening finished so I thought i would share some pics.
It now has a 360-.040 over, nv3550, 14 bolt rear( cut the snot out of it), 44 front(broke a joint already on a test run), 110" wheel base, about a 79" track width, spring over front, mid mounted gas tank, one link rear( work great if you set it up right, just right with the antisquat, using a LeeBoy ball socket fror a grader turrent), Discover SST 37x 12.5x 17 on some new blingy Aluminum wheels.
took it out last weekend to Uwarrie and had a blast. It needs some longer shocks and springs in the rear, front needs some cromo shafts(busted the factory steel shaft backing up slab pile rock, got up there though). anyway I am happy with it so far, cage, fuel injection, rear mid gate(so i can us a wrangler soft top) and paint.
