Cutting off catalytic converter!?
TapouT
Hickory nc
Me and a buddy are talking about cutting off my catalytic converter this Saturday. I have a brand new muffler and tailpipe to put on the Jeep. The cat rattles badly while idling, driving, stalling etc and I think it may be a cause of the cutting off problem. My question is will it cause my Jeep to run any differently? I know it's going to be louder but I'm going to run some pipe where the cat used to be and then into a new muffler and dump. Thanks for the help!
The cat is there for a reason, and you will not get much benefit out of not having one on there. Plus not having a cat on your jeep will just make it pollute more and give greenies another reason to close our offroad parks.
NC state law says that you have to have a cat to get it inspected. I assume it is your '89 that you are referring to.. If I am correct, they will do a visual inspection to make sure it is there.
You are better off just replacing it. They are $80 or so(I should know, I have replaced 2 already and I need another one now!)
I found the inspection process online.. pretty interesting!
19A NCAC 03D .0542 EMISSIONS CONTROL
DEVICES
A civil penalty shall be assessed against individuals who instruct or allow a
person to remove, disconnect, tamper with, or render inoperable any emissions
control device equipped by the manufacturer of any motor vehicle as described
in G.S. 20-183.3.
1. These devices include:
(a) Catalytic Converter
(b) Unleaded Gas Restrictor
(c) Air Pump System
(d) EGR Systems
(e) PCV Systems
(f) Thermostatic air cleaner
(g) Evaporative Emission System (includes gas cap and fuel tank
systems)
(h) Oxygen sensor
History Note: Authority G.S. 20-2; 20-39; 20-183.3(9);
Eff. October 1, 1994.
Here is the link I found: http://www.ncdot.org/DMV/vehicle_se...ionsmanual/download/CR435NCDOTEnforcement.pdf
A universal walker cat from summit at $54. They flow pretty well compared to stock too.
Just "clean" out the one you have and put it back on.
Getting it inspected isn't the problem. I was just wondering if it'd make my Jeep run bad or anything. I doubt it would but just wondering.
It won't run bad.
