d300 clocking ring
xjay
belmont
want to mate my d300 to my 01 xj aw4 looking for local vedor to support or at least board memeber...thanks
i will be running it pass drop
Why not just bolt it on? Both are 23 spline, and if you're running passenger drop, I don't believe you have to widen holes or anything. There may be clearance issues that require a clocking ring but that will all vary depending on year and model of AW4. They bolt right up to NV3550/AX15, so AW4 should be very similar.
Then buy a cable shifter and you're done.
The AW4's output shaft is to long to do that. Basically the "adapter" you are buying is a spacer to make up the gap. Its approx a 3/4" space, if you sider them together you will see what I mean.
Gotcha. NV3550's have the same issue. If you grind about 3/8" off of the output it fits like a glove.
