d300 XJ
MidwayJeremy
Member
Huntersville, NC
Does a dana 300 bolt straight into a XJ 4.0 auto...or what adapters are needed and to run driver side drop...it has to be flipped....just need some info on this if anyone knows where I can go to read up on this would be greatly appreciated
you will need an adapter that will allow you to flip it, have you considered running it pass drop, if you havnt got your axles yet it seems like that the easiest route
yeah Ive basically already got my axles.... 79 F350 D60s....I assume I can run 231 for time being till I figure out which way I wanna go.....
Also with the 231 of course with a slip yoke....just have to have driveshafts made with yokes welded on for d60 then other end 231 yokes...I assume? that will get me atleast rolling...until I decide if I can afford a Atlas or figure out the D300 deal
Ahhh, the elusive Atlas :) I've had several friends running flipped 300s they did themselves. I'm sure you can probably figure it out :driver:
REGARDING
Dianabol Side Effects
Everyone wants nice looking muscles and to get ripped. Especially body builders, weight lifters and anyone competing in the fitness industry. They want anything they can find to produce those muscles. They used to use anabolic steroids, which are now illegal, and actually many do still use anabolic steroids. I don't recommend anabolic steroids for the simple fact that the chronic use causes very dangerous problems, and I don't think you'd look good in the prison orange jumpsuit. Instead I recommend a steroid alternative like Mesobolin.
Dianabol Dbol Steroid
