Bishop
- Jul 22, 2006
- north of Greensboro
I would like to share some info. and ask some ques. about these two front diffs..
Now I know that all this could be answered by saying "just get a D60". I would do that if they were easy to find and wasn't so expensive. But just compare these two.
My first ques. is: Why is the D44 considered a better diff than a 10 bolt? I have a D44 from a '74 blazer and a 10bolt from a '77 3/4 chevy. My plan was to use the D44. I plan on using 38.5 tires. Now in dismantling both diff I did some comparisons.
D44
-hub spline 19 axle spline 30
-axle thickness 1 5/16
-spline contact surface at diff. 1 1/4
-housing tube 2 3/4
-flat top knuckles
Now I know there is more, like ring gear, pinion size and other
that I don't know at this time.
10bolt
-hub spline 19 axle spline 28
-spline contact surface at diff. 1 3/8
-housing tube 3
-also thicker spindles, bigger inner bearings
-knuckles aren't flat top
Also, I know there's more...
Now why would Chevy put a 10bolt under a 3/4 ton if it wasn't good?
Most of the D44s I've seen have been under 1/2 tons.
Now I know there are exceptions.
What I'm getting at is if you had a choice which would you choose and why.
Any other info. about these two is welcomed.
And like I said if I could get a D60 I would.
Thank you, Bishop
D44
-housing tube 2 3/4
-flat top knuckles
10bolt
-housing tube 3
Thank you, Bishop
