kearnsncsu
- Jan 14, 2008
- Thomasville
Does anyone have or know where i can get the 4 prong socket needed to remove thread-in sleeve that the upper ball-joint slides into? When working on my truck this weekend i realized that the ball-joint was loose. When i looked into the problem i noticed that the nut had came loose on the ball-joint and had wallowed out the threard-in sleave inside of the housing. i couldnt get the sleave out with a hammer and screwdriver like i did before.
i also had a question about welding the spiders in my 8.8. I have a LS carrier and open. Is one stronger than the other? Also which welding rod would be better to weld it with, a 60 or 70 series rod?
Thanks in advance for any help.
