DANA 30HP COMPLETE AXLE SPECIAL PRICE!!!
Cperry
Durham, NC
ascontent_iad3_1.xx.fbcdn.net_hphotos_xfa1_t31.0_8_12487316_10f177c67a0955f68a5cd1ee8aab4c26b1.jpg
We have a Dana 30 axle that was completed but the customer cancelled. Our loss is your gain. The build sheet for the axle is:
Dana 30 High Pinion Complete Axle Assembly
(CAA-AH-D30HP)
Select Ball Joints: OE Dana Spicer...
ADD OUTER TUBE SEALS: Tube Seals ($60.00)
Select Tube Sleeves: No Tube Sleeves
Add U-bolt Yoke: Stock Strap Style Yoke
FINISH: Flat Black
Add Diff Cover: Solid Cover ($75.00)
Add C-Gussets: No Gussets
Locker/ Posi Option: True Trac TT 912A585 ($405.00)
Add Artec Truss: No Truss
Add Upper Control Arm Bushing: New Bushings ($25.00)
Select Gear Oil: No Gear Oil
Select Upper Control Arm Gusset: No Gusset
Add Knuckles/U-Bearings: No Knuckles
ADD SHAFTS: Nitro Chromo Shaft Kit ($500.00)
Gear Ratio-Reman Unit: D30HP-410R ($550.00)
HD LCA: Stock LCA Mounts
New Unit Bearings: No Unit Bearings
Normal price is $2265 shipped. We will waive the shipping on this axle. You will receive the axle for $2065 shipped to your door $1965 Picked up from ECGS! Chromoly shaft kit not pictured but is included in the price.
