Dana 35 woes..............help.
Inner Pinion Bearing - 88648
Outer Pinion Bearing - 88649
Timken, BCA, and others carried by AZ, and Advance auto use the same part#( at least the last numbers are the same). I figured this out by ruining a couple of timken bearings, took them down to AZ because they carry Timken. Out of stock, Went to Advance they carried BCA bearings but both bearings had the same part #'s on the bearing. If your search their website all the manufaturers have the same #'s. Hope this helps. Bearings are probably made in the same factory.
