Barnes 4wd
- Aug 6, 2007
- Etowah NC
Dana 44 High Steer Cross-Over Steering Kit
Barnes 4wd is proud to offer the best Dana 44 high steer cross-over steering kit on the market, complete with high quality 1 ton tie rod ends. This kit is a huge upgrade over your stock steering, bigger tie rod ends, stronger 1.5"O.D. x 1/4" wall D.O.M. and if you ever have a mishap on the trail, replacement tie rod ends are easily obtained at the nearest auto parts store. All of the inserts in this kit have a machined hex, so all of your steering adjustments can be made with an open end wrench.
Here are a few of the options offered with the kit.
Standard or high angle tie rod end for the pitman arm: The standard tie rod end will be the same end that is used on the tie rod (part# ES2234R) this tie rod end will not have as much misalignment as the high angle tie rod end (part# ES2026R). Since the tie rod end at the piman arm generally sees more misalignment than the rest of the steering system the high angle joint is usually the best here. The taper on the high angle tie rod end is also larger but the same angle (7° or 1.5" per ft) so you may have to ream your pitman arm deeper to accommodate this tie rod end, we offer the reamer here.
With or without tubing: Some people like to source there tubing locally and some people get it with the kit. Or prices are very competitive with most local welding shops, however the option is totally up to you.
Here are the parts that are included with each kit:
2 1.5"O.D. x 1/4" Wall D.O.M. 54" Long (If You Choose This Option)
2 Right Hand Thread 7/8"-18 Hex Tube Inserts
2 Left Hand Thread 7/8"-18 Hex Tube Inserts
2 Right Hand Thread 7/8"-18 Jam Nuts
2 Left Hand Thread 7/8"-18 Jam Nuts
4 Tie Rod Ends, Dependent on the options you choose
1 Set of Dana 44 High Steer Arms
6 High Steer Arm Mounting Studs With Nuts And Cone Washers (If you choose this option)
Click Here to View Our Dana 44 High Steer Cross-Over Steering Kit
