HGSR
craigslistaholic
- Feb 26, 2010
- kings mountain nc
ok i have a GM D60, i was rolling the truck around and the inner brake pad fell out of the caliper. i remover the wheel to look and what iam seeing is the space between the grooves where the ears on the par ride are so far from the rotor the pad falls out. i switched the caliper brackets side to side and inside out but that would not work at all, so what holds the pads in? maybe the rotors are wrong? this axle has 0 miles since rebuild, was not done by me. the calipers dont volt on with 2 bilts, this one has the "h" bar with thr 5/16 allen screw
