Ridgerunner
- Mar 21, 2005
- Fuquay Varina, NC
I am going to be doing a high steer on my new GM d60.
Where should i get the High streer arms from
pheery said:DO NOT run shakerbuilt arms, crappy service, crappier products. i bought his arms first, they sucked, were not drilled correctly, and the tapers were incorrect. broke 3 3/4 bolts in my steering setup b/c of the crappy design.
saf-t scissors said:The thing I don't like about the Poison Spyder arms is that they're not set up to be used with studs. Yeah, you can use bolts, and you might never have a problem, but studs and conical nuts are clearly a better way of fastening the arm.
