Cperry
- Apr 24, 2005
- Durham, NC
Introducing the ECGS TJ/XJ/MJ high pinion king pin dana 60 front! This is a brand new built to order housing that features a clearanced 60 center section with heavy duty tubes and your choice of inner c's. This is build as a complete axle or as a housing with brackets for you to complete. With the right brake package it can even clear a 15" wheel with the correct center bore! This axle WILL REQUIRE some mods to steering and trackbar.
Dana 60 HP Kingpin Front Axle fits Jeep TJ XJ MJ
The ECGS Dana 60 High Pinon Front Axle features the highest quality parts available on the market. Using the bulletproof Dana 60 High Pinion center section with King Pin design Knuckles and non unit bearing Wheel hubs, makes this the strongest and most serviceable axle on the market. We then build the housing to your specifications.
The base price includes (Roller Axle):
We have 4 popular options for wheel mounting surface (WMS)
- New High Pinion Center Section with 3.5" x 1/2" (.500") DOM tubes
- Heavy Duty Kingpin Inner C's
- Heavy Duty Nodular Cover
- TJ / XJ Specific Brackets w/ option to upgrade to crossover
- Wheel Hubs and Brakes
- 63.785" (One Custom Shaft)
- 65.5" (One Custom Shaft)
- 67" (Stock shaft lengths)
- 69.5" (Full Width Stock Length Shafts)
- Other WMS Options Available Upon Request
