Metto
- Mar 20, 2005
- Cornelius, NC
Customer was having trouble with his 9" exploding and decided it was time to step up to the big league. axle is a Dana 70 HD out of a '70s ford ambulance. was 76" WMS, will be 69" WMS to match the Dana 60 front. Will be running Rockcrusher and Solid inner C's, knuckles, 3/4 ton caliper brackets and steering arms; ECGS 35 spl drive flanges, ECGS Excalibur 300M joints and Nitro 4340 shafts. Diff is centered, pinion angle at 10*, caster at 5*.
Rockcrusher inner C's machined out to 4" for the huge Dana 70 axle tubes
Inner C mockup, still need to trim the tubes down a little. measurement from the back of the inner C to the WMS is around 11.625" (SRW chevy hubs and knuckles)
machining a chunk of a Dana 60 axle tube to make a inner seal housing for the Dana 70. still need to turn down the OD a little. will be running 2 Dana 60 inner axle seals side by side for ultimate leak protection
