death wobble
Let me know what you figure out with yours. I've got DW on my 95 XJ and it is getting worse. Hoping to check my caster this week plus I'm going to replace the upper control arm bushings on the axle housing. They are the only bushings I can find that have any play in them.
Make sure EVERYTHING is TIGHT!! 8 control arm bolts and 2 track bar bolts. Make sure that the track bar bracket is solid and tight. Make sure both lower cam bolts are oriented the same. Adjust your drag link to center the steering wheel. Make sure front wheels are balanced! Check and set the caster angle: http://go.jeep-xj.info/HowtoAlignment.htm Make sure EVERYTHING is TIGHT!
I just did the same lift on my Grand. I don't have it aligned yet and I thought I got the new adjustable trackbar pretty dang close, but same issue. Starts right at 40 MPH like the interwebs say it should. I am gonna look over everything tomorrow and hope I can fix it fast.
