its a 03 tj 4" lift, adj. front track bar, pro comp steering stabilizer, balanced 32" tires... rides great up to 60mph, then goes out of control. any one else have a similar issue?
Have the alignment checked, make sure the place that does the alignment does a caster sweep, as most times if everything is good(no loose or worn parts in the front end) the fix is a caster adjustment.
