Chuckman
- Oct 9, 2005
- Huntersville
Calling all framers! Am planning a code compliant deck in Meck county and need advice. Yes, I am adequate in framing, but since 'the Man' is coming, adequate wont cut it. Question is based on this -I have to run the beams (girders) on either side of my posts, and carriage bolt through x2 bolts. So if I need to splice my beams to get the length required, how do you do this. If I set a 6x6 post and splice my beams end to end, I still only get a small amount of meat on the outer side of each board. 6" post / 2 = 3" with 5/8" bolt in center of that 3" = 1.5" and a 5/8" in the center of that = <1" of wood past the bolt= me worried. Any suggestions? I am assuming that I cant get 8" posts at sLowes.
