83ChevyK10
- Aug 24, 2009
- Kings Mountain,NC
Just need some imput. Gooseneck or tag a long? The trailer is only gonna be a 20' trailer at the biggest. Where/Who has the best deals on a new or used trailer?
Once you haul a gooseneck you will never own another tag along.
Here's the other problem the way it sits now the truck squeezes through fenders on my buddies trialer and i'm planning on going to a wider tire, do they make a trailer that is wider than 82" thats not a deckover?
I have a 20 foot deckover bumper pull that I haul my blazer on and takes almost the whole trailer.A long bed std cab truck hangs off the end.Unless you find a good deal on a 20 footer I'd get a 24 foot at least.If you can find a lowboy that you can make work for ya,you will be better off.My Blazer on 39's catches a ton of air sittin on a deckover trailer.
Mine's 18 on the deck and 2 on the dove.The only problem I see with drivin over tires/fenders is if your trying to load a non-running vehicle it will be a major pain gettin it loaded with no ps and/or a winch.I have a 20 foot deck on my trailer and had plenty of room when my K5 and now the 86 Burb takes all the trailer but still gives me enough room to strap my gas grill in front or behind the truck depending on wether the burb is all the way forward or the rear. When I use my 2500 it goes almost all the way to the front. When I use the 1500 burb it sits closer to te rear of the trailer. hd a 99'ish ford superduty four door (crew cab) long bed on it and it did hang over the rear LOL.
Hey you can't leave out the DuramaxJust because a 6.5 burns oil doesn't put it in the same league with the rest of the turbo diesels.
The deck height difference between a lowboy and a deckover is about a foot. It's a big deal if you're underpowered to begin with.
This is really the same as a lot of other debates -- 2wd tow rig vs 4wd, long box or short, CTD or PSD, gas or diesel, etc etc -- that really have no "right" answer. It comes down to an individual decision about what makes the most sense for your situation.
yes, my trailer isn't a deckover and it's 102" wide (max legal width). the deck extends to the outer edge of the fenders and they are drive over made of 3/16" C channel. i wanted the width of a deckover, but not the associated height. i also didn't want a dovetail. don't expect to find one like that sitting on a lot somewhere, though. kraftsman trailers custom built mine to the specs i wanted.Here's the other problem the way it sits now the truck squeezes through fenders on my buddies trialer and i'm planning on going to a wider tire, do they make a trailer that is wider than 82" thats not a deckover?
