Ok, I picked up my 86 XJ axle for my LJ to switch to HP and 4.10's. I'm going to ditch the vaccum disconnect axles for the ones that are in the jeep now. Question I have is what seal to use on the disconnect axle. Everything I have found says that 87 and later models use the same seals left/right but that the 86 and before have different inner diameter tubes and I will need a special seal. The only reference to this seal I have found is from Warn. Anyone know of a p/n or model I can get this seal from a local parts house?
