I'm still trying to troubleshoot this wobble I have. When it's happening and I look out the window at the DS tires, they look out of round (both front and back). I'm thinking that is a result of the bouncing/wobble, not because they are actually out of round? Happens mostly in the 50-60mph range, although occasionally will start at 45 or go up to 65. It doesn't seem to be consistent in severity either. Just today, I was accelerating to get on the hwy and it started bouncing/wobbling around 50, but then mostly smoothed out at 65. Then, I dropped to 60 and it came back pretty hard. Sped back up to 65 and it was still wobbling pretty good - much more severe than just a few seconds ago at the same speed.
Pertinent info: 9"/D44, leaves in the back, extended radius arm front suspension, 37" Goodyear MTs on recentered H1s with 9 golf balls in each for balance. I scrubbed all the grease out of the tires with dish detergent prior to mounting, so the gold balls should be moving about freely.
Final thought: Am I asking too much from this wheel/tire combo? Seems like Humvees should be able to run down the highway at highway speeds so I'd like to think that this wheel/tire combo would balance out with 15oz of balls in each one.
