buckshot500
- Mar 23, 2008
- Clover S.C.
I put An aftermarket/ replacement, steering damper on my 1990 Yj about 700 miles ago. just today I noticed that the bolt that holds the stabilizer (inboard) to the center of the tie rod, Has been scraping against the tie rod that goes to the steering box. the fix is, to grind the bolt, (where it passes through the nut) off flush with the nut. It actually wore A notch in the tie rod, not too deep. Luckily I noticed it before it got too bad. This only occurs when you turn (full lock) to the right. Feels like A slight hitch, but makes A clunking noise if you listen for it carefully. O.K. now go check yours, feel for the notch. You should be able to see the bolt end worn down too.
