tommyxj2000
Member
- Oct 19, 2010
- ellenboro, nc
I wanna do an axle swap on my xj...whatever I could find, d44,8.8, or8.25 how those configure with the abs system ...or would the abs be useless
I put an 8.8 on my ZJ and the ABS harness is now zip-tied up to the body, the ABS light does come on but it hasn't caused me any problems on the road. Since 8.25's came in XJ's I would assume your harness would plug into it without a problem but I've never dealt with them.
Its my dd...the abs light is already on for another reason...so it would be really wierd with it not on...I like to do some rock crawling but I know my limits...eventually I would like to make this a trail only rig...but not for a long long long time, finances and wife willing....so don't even worry about the abs...ok thanks for the help
For inspection purposes andn legality issuses DO NOT rmeove any light from your cluster. "wink wink" $125 fine, and upon a safety inspection, the right tech, not me, if the car stops without metal to metal or screaming, I'll pass it, they will see the lines and look for the light. Tell you to fix it so they can charge parts and labor to pass your Jeep.ABS would be useless. Pull the dash cluster, remove the light for the ABS and wrap the wires up.
Is this a daily driver? What type of wheeling are you doing with it? If it's all mild, then you might consider leaving the D35 in there. A open D35 would be fine for mild wheeling/trail riding. If you're wanting to crawl rocks, then sure, swap in an 8.25 or 8.8. The 8.25 would be the easiest swap.
Any factory cluster light, removed from it's original housing is illegal, If you remove the light, bust it and put it back in....... totally legal. Must have busted while on the trail.And there's no need to turn the light off for state inspection. Just so long as the brakes work you'll pass just fine. Unless it bothers you.
Not anal...just find one who isn't paranoid bc he's seen sting cars with the lights removed to see if he cautght iIn that case, find a burned out bulb. Or better yet, find an inspection guy who isn't anal.
