door wiring
ncrockinxj
earth
help please
i have a 92 xj laredo and i messed up my doors and bought new/used power doors off of a 90 xj laredo which would just plug right in but the thing is the guys at the junk yard cut the wiring harness so i need to know the colors off or the 92 and 90 so i can splice them in b.c not all the colors match up
please someone help me out my passenger window is rolled down until I get my wires right and its gettin cold out
See if you can pick up a Haynes manual for your truck. You should be able to get them at Advance or whatever. Haynes typically has wiring diagrams in the back.
If nothing else, pull the door panel and hook the window motor to a battery source and roll the window up.
Kevin
thanks for the suggestions i have a haynes and it has all wiring diagrams but the doors
im gettin close to just pulling the panel thanks
I'll check my dad's manual when I go to their house this weekend. The Haynes manual has every wire diagram for the door switches (dome lights) so why wouldn't it have a diagram for the power windows and locks? I'll let you know Sunday unless you findout first.
if you still have the old doors, take the panles off. then remove the wire with out cuting them. Now just hook them up in the same place in the new door.
