ncjeepers
- Apr 13, 2005
- Locust, NC
I want to put a doubler between the later model TH400/NP205 combo with the round pattern.
Has anybody here done it?
I'm leaning towards a planetary set up vs. a 203 for a few reasons...
- four ranges vs three
- weight
- ground clearance
- a round pattern 203 does not exist (but I think it can be re-drilled)
- I would need to find a 32 spline 203
- I would need to change my 205 input shaft to the "short" style
-Considering all this, the cost of the 203 doubler might exceed $1000. I might as well just buy a NWF Black Box.
Or... I could try a 241/205 doubler. The more I research the 241 option, the more confused I get.
Since my 205 has a "long" input shaft...
- Will I need a different adapter between the TH400 and 241?
- How do I bolt up my 205 to the 241?
- Will the 205 shift rods clear so I won't need a rear shift mod?
Also, what vehicles would have a 32 spline 241?
And finally, why hasn't anybody done this with the NP208? TH400/NP 208's are cheap and plentiful.
- weight
- ground clearance
