Shags
Member
- Oct 31, 2007
- Wilmington NC
Hey all, just bought a 89 f150 with a 6" suspension lift and a 3" body lift. I bought it without a front drive shaft, well I went and purchased 1 today and put u joints in it.
My buddy has the same lift on his bronco with stock front drive shaft.
Well every time I go in 4wd the front end doesn't seem to want to budge and the rear end hops and spins, something is binding.
but in 2wd it runs great.
did I install the drive shaft wrong? I tried to keep both sides equal, whats wrong? >.<
will I be okay to drive it to work in 2wd with the hubs unlocked tomorrow?
Additional information: when the drive shaft isnt connected it runs great in 4wd high and low, (just the rear spinning tho you can fell the 4low torque) also, im having trouble with my front left Warn hub, when I press it in, it goes from lock to unlock simple, but if I pull it out, it free spins.
Any help would be great, thanks.
