willness33
Here for the memes
- May 3, 2005
- Alexis,NC
I'm working on Dad's '54 3B. My goal is to replace the rear brake backing plates D/T rust/rot. The CJ has the offset 10 spline D44 with the 2 piece shafts. I've got the rear hub nut off and the 6 bolts that hold the retainer and backing plate off, but can't get the outer hub to release from the shaft nor can I get the inner shaft to slide out. All I really need to do is get the hub off, but I've already broken one puller and beating it with the BFH isn't really accomplishing anything. Is there any special tricks to this or do I just need a better puller and have another go at it?
