East Bend Mud Bogg 4-10-2010
transman
East Bend
* STOCK STREET 34" AND UNDER TIRES
(Stock Street Vehicles cannot run in any other classes)
1. Must have full factory body & frame.
2. No cutting on body or firewall except trimming fenders for larger tires.
3. Stock wheelbase only; no engine set back.
4. Must have factory dash; after market guages ok.
5. No gutting driver's compartment.
6. Must have factory type suspension; lift kits ok; ladder bars ok; no floaters; no 4 links.
7. Must have same engine make as vehicle.
8. Stock engines only.
9. Headers ok; aftermarket carburetor ok.
10. No aftermarket blowers or turbo's on gas engines.
11. Gasoline or diesel fuel only; no nitrous oxide.
12. Uncut DOT tires only 34" maximum.
13. Diesels with stock turbos.
* STOCK STREET 35" AND OVER TIRES
12. Uncut DOT tires only 35" minimum.
MODIFIED CLASS
1. Uncut DOT tires.
2. No aftermarket blowers or turbo's on gas engines.
4. Aluminum intakes ok; headers ok; aftermarket carburetor ok. Engine modification ok.
5. Gasoline or diesel fuel only; no nitrous oxide. No alcohol.
MODIFIED UNLIMITED CLASS
1. NO NITROUS OXIDE
RULES
1. All drivers must have drivers license.
2. Any driver under age 18 must have a guardian present or a notirized letter from guardian.
3. No nitrous oxide.
4. No alcoholic beverages allowed.
5. All classes are subject to be split more by tire size.
6. All vehicles will be inspected by the Inspection Crew.
7. Seatbelts or safety harness must be worn while in the pit.
8. Helments must be worn while in the pit.
9. No riders in the vehicles while in the pit.
10. In the event of disqualification of a vehicle, NO refund will be given.
11. Not responsible for accidents.
12. East Bend Volunteer Fire Department Staff will have final say on rules and classes.
East Bend Mud Bogg
East Bend Mud BoggGate fees: Adults 10.00 Children 6-12 5.00 under 6 free Gates open at 1pm Registration 1-3 pm Runs Start 3 pm. You look up on facebook East Bend Mud Bogg Thanks The date is 4-10-2010
