Mac5005
- Oct 19, 2005
- Rocky Mount
So I’m wiring up some led lights behind the grille on my wife’s 4Runner, and I can’t remember how I did this before on the suburban.
I have an on/off/on switch.
I’m wanting the leds to be able to be switched on all the time, off, or on only when high beams are on.
Have them on the bench at the moment to test the wiring.
First try :
I switched the ground side, and had the normally closed contact on the relay hooked for ground when the switch is in “on all the time position”.
The normally open side of relay was triggered closed when the high beam wire powers the coil side of the relay.
It worked, for the most part.
Turn switch “on” lights come on.
Switch off lights don’t come on regardless of hi beam on/off.
Turn switch to “high on” lights come on/off with the relay trigger ( high beam on/off).
Works as it should. Except:
When switch is in “on” position the leds come one, but turn off when you activate high beams.
I know I can do it with two relays but trying to it with one, and I can’t remember or find a good diagram of how to do so.
Thanks
First try :
Thanks
