Avoid getting water on the ecm.I really need to give my 1991 YJ a good clean under the hood.
Looking at pro tips on what to avoid spraying directly on these engines.
I plan on using a 50/50 mix of simple green and a water hose. Not going to use a pressure washer.
x2 also keep away from the alternator if you canI've pressure washed my engines many times. As said above, just avoid directing the spray on the air intake, computer and distributor.
