eye to eye shocks
Bobby D.
Trinity, NC
Is there anything wrong with mounting eye to eye schlock with the eyes perpendicular to each other rater than parallel?
attachment.php
The other end of the rod is a circular psiton it doesnt know which way it turns.
As long as you are exerting linear forces on the shock you should be fine, if you get into lateral forces....well bad things will happen.
drew is a master fabricator... however if u have lots of wheel travel mounting the shocks with the bolts parrallel to the axle can cause the shock eye to bind. ive seen it happen when using air shocks or coilovers
