F350 Axles?
Sandiggr
Member
Savannah,GA
Got a set of F350 axles from a 2004 ford superduty diesel for next to nothing . Never had anything ford . I think I got the 60/70 combo . Are these good axles to run ?? w 38s ? going to throw a locker in rear . Thanks
Dana 60 front and Sterling 10.5 rear. They are good axles, but take a metric bolt pattern. 38's will be fine with them.
Ford axles
Thanks for the info . Right now I have the axles ,a TJ Frame that Ive set up w 4" OME springs . Is there a certain company that supplies parts for these . The locking hubs are junk and I need calipers , brakes , etc . Want to upgrade all this .
Also , Are these 30 or 35 spline ? Thanks for all the info .
Autozone carries all the parts. The stock hubs, calipers, brake, etc are really heavy duty. The inner shafts are 35 spline and the outter 30 spline. If your hubs are broken just get warn replacements.
I'm not sure on unit bearing axles if you can upgrade to 35 spline on the stub without changing the unit bearing? That would be the only upgrade other than gears and locker I would do.
You do have to upgrade the unit bearing to go to 35 spline stubs. It may be possible to modify a stock one to accept them, but I'm not completely sure. Branik Motorsports sells unit bearings that will accept 35 spline stubs for about the same price as stock ones though.
F350 Calipers
Now I know why I got these for nothing . I need calipers and the hardware to bolt them up . I need all 4 corners , anybody got any ?? willing to ship ? Thanks
F350 Calipers
I need some calipers for core , most places want 60-80$ , and the new calipers are about the same $ . If I bought 4 new calipers , rotors , brackets , and hardware , i would hit $1000 easily . Just trying to bring that down a little . I guess I 'm shootin in the dark hopin to get a set of 4 for around $80 . That would save me a whole lotta dollars in the end .
go to the junk yard and pull some calipers from something random thats close in size. The parts stores don't really give a sh!t what calipers you bring back so long as they have something to rebuild for future sales.
F350calipers
There are 4 major junk yards around here and Ive been checking consistently and havnt gotten anything yet , or when I do find some they want the same $ as the parts store . I found alot of f150 but nothing 250 or 350 . I did find a set in jacksonville FL , yesterday , going to take a ride this weekend and see . I will post pics in a day or 2
