Not sure why you would "want" vinyl and crank windows but whatever trips your trigger. I do like mine fully loaded with the rubber mat still
As far as gas, there is NO reason to run anything but regular in it. The 6.0 is so severely detuned and runs low compression it doesn't need the higher octane. Even if you were to experience any detonation under the hottest and most strained conditions the knock sensors would retard the ignition temporarily.
Now then if you were to get a tune (NOT a handheld-diablo, superchips, hypertech or any of that crap) but an actual PCM tune via EFI-Live or HPTuners, there is a ton of power to be found in simple tuning. Nelson Performance has recorded gains of 50-60 hp from nothing but a tune.
With that much timing, you would want to run premium to keep the knock sensors from retarding the timing, but it is well worth it. Other tuners should get similar results and there are plenty of good ones out there.
Keep in mind, you may not want to advance it that far since you did buy this primarily as a tow rig, with that said, I have towed 10k with mine, with similar tuning on 37-38" tires (regeared of course) with no pinging, or temp issues.
