For the front, you can convert to the later model FJ40/FJ60 rotors, or since you'll want to upgrade to the minitruck knuckles, just get the whole setup from that. Whole axles can be had for little more than $150, and you can use the birfs, knuckles, spindles, lockouts, etc..
The only downside is that minitrucks are solid rotors, while the FJ's were all vented. Not a HUGE deal unless you drive alot loaded.
For the rear, I believe the setup is nearly the same as the minitruck kit, but since I had minitruck outers on my axle, I can't swear to it.
Don't forget, you'll want a 1" bore MC, or even a tad larger.. Later minitruck/FJ80 was 1" bore, bolts right up to your booster. I am/was running a 1" bore MC, and though I could bottom the pedal, it would damn near lock up the front 38's, would easily lock the rears. (You'll want an adjustable proportioning valve.)
