flat fenders
wranglerrambler
oxford,nc
Has anyone on here used the smittybilt flat fenders for a TJ? Looking at getting these to replace my hack job. If not... what type do some of y'all use (other than the cut stockers)
I have and instslled the smittybuilt flat fenders and really like them, take youre time installing them and FOLLOW THE DIRECTIONS EXACTLY. you will neeed a sawzaw with a fine blade. they seem to be pretty tough.
I have the Gen Right gen I with 3" flare on my TJ, I like them, and the gen III stuff is even better. I have Rokmen hi fenders on my LJ and they are awesome. They don't come built though. You'll need a welder to get this job done, but it's great once they're on. I fit 37s with 2.5" lift.
Here's a pic with one stock fender and one Rokmen hi fender
Uploaded with ImageShack.us
I went with Poison Spyder tubes with a 3" flare
http://modernclassicenterprises.com/
Being made from UV protected impact-resistant ABS plastic, if they do happen to contact a foreign object, whether it is a tree, rock, or whatever else you can try to squeeze a Jeep through, the Flexible Fenders are designed to elastically flex and return to their normal shape. Further, these fenders are extremely lightweight, paintable, and cost substantially less than a comparable aftermarket tube fender.
NO Lift/31s
2" OME 1" BL 33's
