Barnes 4wd
- Aug 6, 2007
- Etowah NC
Introducing our flat hydraulic steering valve mount is designed for custom builders that are looking for a blank slate that they can modify to suit there needs. This bracket is designed to be cut to fit your particular application, this bracket is ideal if you are wanting to put your hydraulic steering valve in the same location as the factory steering box. The bracket measures 8-1/4 inches x 4-1/4 inches, it is 3/16 thick and has a 4 x 3-1/4 bolt circle to accept most steering valves. This bracket will ship bare steel.
