Tacoma747
- Mar 20, 2005
- Winston-Salem
I made a shroud to mount an electric fan, to replace the ones I had which were poorly mounted, but it turns ou the fan I was going to use is broken, so I would have to buy a new one.
I also got a flex-a-lite fan, one of the nice metal ones, we took it off a racecar at work, all I have to do to make it fit is get some longer metric bolts, I bought a spacer at Oriellys for $10 to make it clear the belts and pulleys.
I am thinking that since it is not clutch driven, it should never fail, plus, I don't have to worry about the electrionics for the electric fan, is there any reasons I should spend the extra money and get an electric one?
The only reason I can think is when going through water the fan won't throw up alot of water, but I would have to be in DEEP water for it to touch the fan, so I don't see that being a problem.
Thanks for any opinions.
